Machine Vision
Is it pattern matching the best way to check presence and orientation of components on a pcb board?
Hi, like i ask on the title i need some hint about this. I need to program a simple AOI machine that must inspect a pcb board and find if all the components are correctly placed and oriented. I though to use the pattern matching with a good template of the object to inspect. Can it work?
All kinds of tips that may come to your mind please tell me, because this is the first time i try a task like this. I already have some experience in image manipulation but not in AOI machines.
Francesco.
(4,862 Views)
Hi Francesco,
you can find some useful information here, here and here.
I hope this will help!
Bye,
Licia
(4,843 Views)
Thank you very much Licia. Even if i have already read these links i appreciate the suggestions. Smiley Wink
(4,836 Views)
