Machine Vision
Is it possible register vision80rte via code ??
a question...
I upgrade my NI-IMAQ from version 6.0 to 8.0. When i create a application i
include VisionXXrte.exe to register licence. With ver.6.0 i did it via code
with /qn to hide installation. With new version i need to insert serial
number. Is it possible write s/n in command line ??
Any suggest ??
Thank's
(3,001 Views)
marco,
Read the following KB...
How do I Deploy LabVIEW 8.0 Applications with NI Vision 8.0? [broken link removed; article no longer available]
I believe option 2 in the KB... "To include the Vision Run-time Engine with your deployment using the LabVIEW installer for executables"... will include the RTE in your installer and the end user will not need to activate.
If this does not work tell me and we will see what we can do.
Lorne Hengst
Application Engineer
(2,986 Views)
