Machine Vision
Is it possible to communicate with devices in Vision Assistant using my ethernet while another network interface is in use?
Hi, I need to keep my wireless connection enabled while my CVS is connected to my ethernet. So I have 2 network interfaces on my computer. The CVS communicates fine in Vision Assistant and MAX while the wireless is off, but doesn't communicate if the wireless is enabled. Is there a way of adjusting my IP settings to keep the two interfaces running simultaneously?
(2,983 Views)
Duplicate post, please continue the discussion here:
http://forums.ni.com/ni/board/message?board.id=200&message.id=19661&jump=true#M19661
Thank You
Eric Reid
Thank You
Eric Reid
Motion R&D
(2,956 Views)
