Machine Vision
Is there a PCMCIA, Parallel 16b Frame Grabber?
Can someone suggest a PCMCIA Frame grabber to use with Labview.  I need a 16bit parallel video bus.  I am currently using the PCI-1422 on desktops, but I need to make a test station to travel with.  Thanks.
(3,189 Views)
There are not any PCMCIA frame grabbers that I am aware of.  I would consider a couple of possibilities.  If you can, switch to a firewire camera which is easy to interface to a laptop, or find a PCMCIA -> PCI expansion box that will let you use your PCI-1422 card with your laptop.  I know there are one or two companies that make these expansion boxes, but I don't recall the names of any of them at the moment.
Bruce
Bruce Ammons
Ammons Engineering
(3,187 Views)
