Machine Vision
Is there a method to stop the autoscaling in an Image indicator?
I am processing low light-level images into an Image indicator. I need the ROI tools so using an Intensity Graph is not practical. The image background brightness fluctuates indicating a form of autoscaling taking place in the labview indicator. I've monitored the pixel values and they show no corresponding fluctuations. I've looked at the Property Node for setting the max and minimum 16-bit display mapping but to no avail. I would appreciate any feedback.
Best,
Mike
(2,862 Views)
Mike,
What you want to do is change the 16 bit mapping to a fixed shift to get to 8 bits.  Just right click on the indicator on the front panel, select 16 bit display mapping, then select downshift as the method.  You will have to specify how many shifts to perform.  For 10 bit images, shift 2.  For 12, shift 4.  This will shift the highest bits into the proper location.
This display method will not flicker or vary.  However, it may be a bit dark so you can't see anything you want.  I recommend switching the Palette to Gradient.  This uses false coloring to highlight details, and you can see what you need.
Bruce
Bruce Ammons
Ammons Engineering
(2,857 Views)
