Machine Vision
Is there a way to determine if a IMAQdx camera session is still valid or not ?
If it's valid, IMAQdx Open Camera.vi will return an error.
If it's not valid, IMAQdx Close Camera.vi will return an error.  And IMAQdx Close Camera.vi is very slow when the camera session is not valid.
George Zou
(5,194 Views)
What do you mean by "not valid"? Do you mean already closed or the camera has been removed but your session is still open?
(5,160 Views)
Accepted by zou
I mean IMAQdx Open Camera.vi haven't been called yet, or IMAQdx Close Camera.vi has been called.
Although there is no property node for that purpose, other properties, such as camera vendor name, are acceptable workarounds.
George Zou
(5,155 Views)
Accepted by zou
For that scenario, the "Not a refnum" primitive should work, I believe.
(5,151 Views)
Interesting.
The camera session is "cam0" when prob before and after call IMAQdx Open Camera.vi.
No change, not empty.
That deceaves me.
George Zou
(5,139 Views)
