Machine Vision
JAI AD-080 CL drivers don't work
I'm trying to use a 1429PCI-e frame grabber with a JAI AD-080CL camera.  When I try to collect a frame, I get "Error 0xBFF60122 This firmware is not capable of acquiring from a camera."  How do I update the firmware to collect with this camera?
Todd
(3,377 Views)
Hello tirgang,
Has your camera setup worked in the past, or is this the first time you’ve attempted to use it? It is possible that some settings were changed in the camera file associated with your JAI camera. Please download the camera file for your camera from ni.com/cameras, then set this as the camera file for your PCIe-1429 card in the Measurement & Automation Explorer software. The specific steps for this procedure can be found here.
Let us know if your problems persist after updating the camera file.
I hope this helps 🙂
Message Edited by DjDaveNI on 10-16-2008 10:44 AM
Message Edited by DjDaveNI on 10-16-2008 10:45 AM
David G
Sales Engineer - SE Michigan & N Ohio
(3,352 Views)
