Machine Vision
JAI AD-080 camera colors mapped wrong
I'm using the JAI AD-080CL camera into two 1428 boards. I get monochrome images from both sensors OK, but I want to use the color capabilities of the color sensor. I've been changing parameters in the icd file as shown below and get a 'color' image, but yellow is appearing as blue.
icd 1428 params:
bit depth - was 8 now 32
bits per component - 3
components - was 1 now 3
Suggestions?
(3,433 Views)
You could download the camera files from here.  I noticed that there is a Full Color mode supported in the file and it uses a Bit Depth of 16.  Anyway, you should download and use those camera files (one for each sensor).
Dan Press
PrimeTest Automation
(3,411 Views)
