Machine Vision
LV_AviMovieInfo with DVencoder
I want to read an AVI encoding with the DVencoder compressor in my VI.
I need to know the timing, so I use the function "LV_AVIMovieInfo", in the output string I extract the framepersecond, and with this codec the response is always 29framepersecond while my file is in 10framepersecond (if I change the framepersecond of my file, I always have 29framepersecond with "LV_AVIMovieInfo").
Is it possible to have the real framepersecond of my AVI (encoding in DVencoder) with this function?
Note : If i use the mjpegcompressor, all is OK.
(2,861 Views)
Could you post your vi or a simple example reproducing the issue ? If possible with your AVI ? It would be useful for me to reproduce it.
(2,854 Views)
