Machine Vision
LV2009 and Vision - Crash Displaying U16 Image
Create a Grayscale U16 image and resize it to any size, e.g. 640x480. (The image values will all be 0's.) Display the image using Image indicator. If "16-bit display mapping" is set to "full range", the image will be displayed without any trouble. If "16-bit display mapping" is set to "90% dynamic" or "given percent range", LabVIEW will crash. An example is attached.
(3,576 Views)
I was able to reproduce this issue.  This was reported to R&D (#194334) for further investigation.  Are you looking for a work around or do you have something working for now?
Thanks for the feedback!
Alex Person
NI-RIO Product Support Engineer
(3,568 Views)
I am all set for now. Thanks!
(3,562 Views)
