Machine Vision
LVDS Camera Files
I have both LVDS and RS422 versions of the PCI-1422 capture devices.   When generating camera files for LVDS parallel/digital camera's do the parameters in the camera file still get defined as RS422 and not LVDS?
Also, what is up  OnBoardClock (20) does this parameter ever get changed say if my pixel clock is 75Mhz?
Thanks in advance,
JS.
(3,539 Views)
Hi JS,
You're correct about the RS422 in the camera files.  Some parameters are defined as RS422 even for LVDS cameras.  This is because RS422 is used to mean 'differential' and applies to both types of cameras.  The opposite value is TTL.
Brandon M.
(3,522 Views)
