Machine Vision
LabVIEW 7.1 issue with IMAQ Vision 7.0
I have LabVIEW 7.1 installed in my computer and just testing IMAQ Vision 7.0 with it. When I select Tools>Create LabVIEW VI… in the Vision Assistant the software tells me "National Instruments LabVIEW and IMAQ Vision not found" "Migrating this inspection to LabVIEW requires that you have LabVIEW 6.1 or higher and IMAQ Vision 6.1 or higher installed on your machine." Why? Is there anything wrong with my NI software versions or do I need to link them first?
Manuel Bandala
(3,222 Views)
Hello Manuel,
Thank you for using our discussion forums. Please download and install Vision Assistant 7.0.1.
Once you install this update Vision Assistant will be able to generate code for LabVIEW 7.1. Have a great day!
Nipun M
(3,203 Views)
