02-11-2021 07:21 AM
Sorry for the late reply, i figured it out by myself in the end. I found out that the pointers were the problem.
What I do now is during the initialisation I create a HWindowControl (HSmartWindowControl is NOT working properly, in my case at least), define all the settings (Handle, implementation in HDevEngine,...) and then I send the WindowID as an input of the procedure I call (which I created myself for other data manipulation and contains "visualize_object_model_3d" at some point). As a result I get the display window directly in the front panel of my VI.
No doubt your solution works as well but this is way is a bit different so I thought I would share it if that can help someone. I have been struggling with this for a long time.
Thanks for your time anyway.
05-05-2021 08:19 AM
HI dadreamer,
Using the vi: LV_Image_To_Halcon_LV2014.vi 31 KB ,Ican conver a gray image to halcon image;
But,now the image is a RGB format , I don't kown hao to do. Can u help me?
05-05-2021 10:27 AM
This is for 3-channel RGB image.
05-05-2021 10:50 AM
Nice,just very thankyou for you help!
09-13-2021 10:27 PM
Test under this program LV TO HALCON image running time is long will be out of memory and then an error please help below the answer thank you LV2014 HALOCN12.0
09-14-2021 01:04 PM
You repeatedly allocate the memory with DSNewPClr and nowhere you free that memory with DSDisposePtr. That is the issue.
09-14-2021 09:45 PM - edited 09-14-2021 09:55 PM
Where will the release function report an error
09-14-2021 09:52 PM - edited 09-14-2021 09:57 PM
1631673723(1).pngThis change is good
09-15-2021 03:34 AM
You should dispose of the memory right after you have generated a HImage object with GenImage1 or GenImage3 method. This is from the sample that I posted earlier.
Please, don't use CIN method because it's unreliable in some cases.
09-15-2021 04:06 AM - edited 09-15-2021 04:11 AM
It feels good to try. Does LV call Halcon have many bugs
