Machine Vision
LabView executable on Windows Embedded Standard 7
I will like to know if LabView executable with IMAQdx Vision code can be  run on Windows Embedded Standard 7. Thanks.
(4,102 Views)
Greetings,
Most certainly, you should be able to use LabVIEW Executables on Windows Embedded Standard 7 that contain Vision VIs. The cRIO 9082 is a great example, for it uses WES7 and brings in GigE Camera support.
Cordially;
Simon P.
(4,089 Views)
