Machine Vision
Labview 8.6 and Window 7
I'm getting "Windows SDK function returned an error" while installing 8.6 on win7.
Anybody run into this error?  Any solutions?
(6,977 Views)
[...] this is a known issue. 8.6 is not officially supported with Windows 7. You can try what this KB article says, and if that doesn't work, you can try to run Windows 7 in XP compatibility mode to see if that allows you to install it.
(6,965 Views)
