Machine Vision
Labview Interface with Cognex
It's an Insight Cognex camera. now i try to use telnet commands to see if it's working. thank you!
Message 11 of 20
(8,002 Views)
HI i connected Labview with Cognex using .net .
but the cognex display image takes so much time .
Message 12 of 20
(7,981 Views)
can you elaborate on this?
what takes time? i have used this before and its works in real time for me. is it not the inspection processing time that is long?
Message 13 of 20
(7,974 Views)
Hello, you can insert code vi Please....
Thank you very much.
Message 14 of 20
(7,875 Views)
I am trying this too ..
I would like to have labview communicate with : http://www.cognex.com/products/machine-vision/in-sight-5000-industrial-vision-systems/
If you have done it, and can share the VI, that'd help me get started.
Thanks.
Message 15 of 20
(7,564 Views)
Sorry i dont have the vi anymore, but there are two ways of doing it.
either buying the Sdk or using the native mode commands, the sdk allows you to acces all the features and get the image and spreadsheet into labview, native mode just allows you to pass data to and from the spreadsheet and change jobs.
i can supply the sdk, get in touch if you need it.
Message 16 of 20
(7,558 Views)
Sorta new on here , how do i get in touch with you? I can get the SDK and take a look at it (to see if its useful)
Message 17 of 20
(7,501 Views)
Have a look here: http://www.cognex.com/support/downloads/File.aspx?d=3127
you may need a license to use it though
Message 18 of 20
(7,497 Views)
I know of that.. if I had the licence, would I be here?
Thanks anyway.
Message 19 of 20
(7,495 Views)
Its €1200 if you want a copy
Message 20 of 20
(7,485 Views)
