Machine Vision
Labview not found
I'm trying to generate Labview code from Vision Builder 2.6.1. I have Labview 8.2 installed on the system, but when I try to generate the Labview code it tells me that Labview is not installed. How can I fix this?
Thanks -- Gerard
(3,499 Views)
Gerard,
    You should be able to create code from VBAI for LabVIEW with those versions.  It sounds like there's a possibility of a corrupt install of one of the pieces of software.  When does the error appear?  Immediately when you try to generate code?  You may want to try going into the Windows control panel and then to Add/Remove Programs and repairing your LabVIEW install.  Thank you.
-Allison S.
Applications Engineering
-Allison S.
Calibration Services
Product Support Engineer
(3,480 Views)
Hi Allison,
I got Labview to work, so I no longer need the vision application builder to work.
Thanks -- Gerard
(3,465 Views)
