Machine Vision
Labview program crashes
I've build an application and run it. After one day it crashes with error "Fatal internal error: "MemoryManager.cpp", line 406; LabVIEW version 8.5.1". I clicked OK and got next error "Runtime error!; R6025 - pure virtual function call". I'm using LabVIEW Run-Time 8.5.1 and NI-IMAQ 4.0.0 and NI Vision 8.5.0. I've made many Labview applications and never experience such problems. Is someone familiar with this problem and can give me some advice on how to start solving it.
andrej
(4,667 Views)
Is what your application is trying to do anything like this?
http://forums.ni.com/ni/board/message?board.id=200&message.id=22567&query.id=1238035#M22567
(4,647 Views)
I have only one camera. But I have never had problems with Image Acquisition Software.
(4,639 Views)
I have a smilar problem!
(4,600 Views)
I found out that the error has occured in lvrt.dll module because of fault address. So I reinstalled NI software and now I am testin application. So far it is ok. If I got the same error again I will post it here.
Sadok, you can see such Windows errors in Event Viewer (Control panel -> Administrative tools ->Event viewer -> Application).
Best regards
(4,592 Views)
