Machine Vision
Laser triangulation
Hello all,
I have been doing tools survey for constructing 3D images in Labview based on Laser triangulation. I have gone through forums regarding this (http://forums.ni.com/t5/Machine-Vision/3d-machine-vision-library-3dmvl/m-p/2153462/highlight/true#M3... forum and found some third party tool boxes.
I have Labview full version and all vision tool boxes installed. I would like to know , is there any Labview functions ( not third party ) to integrate the laser sheet of light into a single surface with adjustable acquisition parameters ???????
the tool boxes in the above link exactly fullfill my requirements, but I want to implement them with Labview Vision tools. Please let me knowif any one has done some research
Regards
Neo.
(6,133 Views)
Hello Neo6,
imaginglab is one of the alliance partner of National Instruments.
They have specialized in this topic and developed spezific libraries.
I have not found this function in Labview yet.
Philipp
(6,096 Views)
Hello Philipp,
Thank you for your reply. Imaginglab is also in my list of options. I am searching for basic functions developed by LabVIEW. Lets wait for some more ppl to respond.
Cheers Smiley Happy
Neo
(6,094 Views)
what did more time with the issue teach you guys?   I'm a student looking to prototype an r3 scanning, object sorting system, and would greatly like to know whether or not labview can do what I need on its own.
many thanks,
Joseph
(5,895 Views)
some time ago,I have been doing some laser scanning tests of my own. It is performed with labview libraries only. The only problem is that my system was not fully calibrated.
But,please see for yourself at the following link:
https://decibel.ni.com/content/blogs/kl3m3n
It is divided in three seperate posts.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,887 Views)
Hi Klemn,
Good info... Will give a try and report you back
Regards
Neo
(5,880 Views)
If you want to perform laser triangulation in LV, using only IMAQ, you need to develop an image processing pipeline that can take in a series of images of the laser line, as viewed by a 2D camera, and process the laser profile into a 1D array of values for each image.  Each subsequent 1D array will then be appended to your result image, which will be a raster height map.
To increase processing speed, you will want to crop the input images to include only that part of the image that contains profile data.  You will need to establish MIN and MAX of the profile for this.
Once you have your height map, you can apply parallax correction of the X values, and build a point cloud.  For calibration, you will need to apply gain/offset for each of X,Y,Z, and possibly do a pitch/roll/yaw correction if the imaging surface is not optimal.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(5,871 Views)
