Machine Vision
Learn Golden Template Error:Invalid image border.
I'm using Vision Module 8.5 and imaq VC++ 6.0/VB 2005
/ / The following access code from the clipboard image
/ / SaveObject2Bitmap (m_ImageMinuend, bmTemplate);
/ / CopyBitmapToClipboard (NULL, bmTemplate, NULL);
   ImaqClipboardToImage (imTemplate, NULL);
  / / Pattern Match: Learning
  ImaqLearnPattern success = (imTemplate, IMAQ_LEARN_ALL);
     If (! Success)
         Char * err = imaqGetErrorText (imaqGetLastError ());
         :: MessageBox (NULL, err, "Error Learning Pattern", MB_OK | MB_ICONERROR);
         ImaqDispose (err);
   Goto FailMatch;
/ / SaveObject2Bitmap (m_ImageMinuend, bmSearch);
/ / CopyBitmapToClipboard (NULL, bmSearch, NULL);
  ImaqClipboardToImage (imSearch, NULL);
  / / Golden Template: Learning
  ImaqLearnGoldenTemplate success = (imTemplate, IMAQ_NO_OFFSET, NULL); / / error,
 / / Error usually: Invalid image border.
But it done in VB 2005:
        'Learn template
        CWIMAQVision1.LearnPattern2(TemplateImage, LearnOptions)
        CWIMAQVision1.LearnGoldenTemplate(TemplateImage)
            'Perform the Inspection
            MatchReport.Item(1).Position.CopyTo(Alignment.Position)
            Alignment.Angle = MatchReport.Item(1).Angle
            Alignment.ScalePercentage = 100
            GoldenTemplateOptions.BrightThreshold = 100
            GoldenTemplateOptions.DarkThreshold = 100
            GoldenTemplateOptions.EdgeThicknessToIgnore = 1
            CWIMAQVision1.CompareGoldenTemplate(CurImage, TemplateImage, Alignment, GoldenTemplateOptions, DefectImage, DefectImage)
NO ERROR
whether the use of function ImaqLearnGoldenTemplate properly? Jifen reply, Thanks!
Message 1 of 1
(3,271 Views)
