Machine Vision
Line fit issue problem
On attempting to fit a straight line, though points in an image the following error is observed
https://www.ni.com/en/support/documentation/bugs/18/ni-vision-development-module-2018-known-issues.h...
697023 —  When using the IMAQ Fit Line VI, if the resulting line is either vertical or horizontal it is possi...
How to rotate the points and perform the above said work around?
(2,498 Views)
This error is obtained on using the imaq fit line on points detected by IMAQ edge tool 3
On using IMAQ find straight edges 3 and IMAQ find edge there is no line detected.
(2,492 Views)
