Machine Vision
Lm386N-1 amplifier not working
I made this:
https://easyeda.com/Basilisvirus/Op-amps
Using Lm386N-1 amplifier.
It doesnt output any sound on the output. I have managed to make it work once, now it doesnt, i dont know why. I also tried to add a 10uF for maximum gain and nothing changed.
I followed the datasheet's schematic, how is it possible its not working?
Datasheet: (page 😎
http://www.ti.com/lit/ds/symlink/lm386.pdf
(2,472 Views)
Hi Basillisvirus,
How are you using LabVIEW/ NI Hardware in this system? If you have questions on the Audio Amplifier, you will have better luck contacting Texas Instruments as they are the manufacturer for that product.
Also,please note that you posted in the Machine Vision section of the forums. Are you using any Vision hardware, or is this just an audio application? If audio, you may have better luck in a forum that more closely matching that hardware/software you are using (search on the Discussion Forums main page).
Thanks!
Erika
Technical Support Engineer
(2,435 Views)
