Machine Vision
Load nivismgr.dll cause APPCRASH in Vista
Hi All,
I'm using Vision Development 8.6 and Vision Acquisition 8.6 to generate a DLL that be loaded by C++.
When I run my C++ code, there is a APPCRASH message.
My OS is Windows Vista Business, SP1. I wonder if there is any compatible problem. And how can I resolve this problem?
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: Test02.exe
  Application Version: 0.0.0.0
  Application Timestamp: 4b8f79c1
  Fault Module Name: nivismgr.dll
  Fault Module Version: 8.6.0.49152
  Fault Module Timestamp: 486071d2
  Exception Code: c0000005
  Exception Offset: 0000aaf3
  OS Version: 6.0.6001.2.1.0.256.6
  Locale ID: 1033
  Additional Information 1: ae94
  Additional Information 2: d532745beacfec44407a8946cc0b0c41
  Additional Information 3: 366b
  Additional Information 4: abeffdb03a863eec2aaa6caa71dd5383
Read our privacy statement:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Thanks alot.
Feel Good Inc. Love forever love is free. Let's turn forever you and me.
(4,129 Views)
Can you post your code?
(4,125 Views)
Hi Muks,
Do you want me to post C++ code?
I think the code is ok, because after running it, I can get right return values.
But when it finished, there is a APPCRASH message.
(4,104 Views)
After running the code successfully you experience a crash?
(4,098 Views)
Yes, I can get correnct return values.
I think this may be incompatible problem between LabVIEW and Vista.
(4,096 Views)
This problem has been cased by OS.
The Vista that had been installed on IPC has sth. custom-made.
(4,039 Views)
