Machine Vision
Loading differnet ICD camera files programatically
I want to programmaticaly change which ICD file is used by MAX. Is there a simple way to do this?
Alex
(3,731 Views)
Hi Alex,
If you use the ReadAttributes/WriteAttributes functions/VIs, they will update the default ICD file used to whichever one you save/load.
Eric
(3,727 Views)
This vi allows you to change which icd file is saved in the iid file, which I think is what you want (saved as v. 8.0).
Randall Pursley
(3,721 Views)
