Machine Vision
Look up table
Hi Klemen,
                if you can integrate it with the attached file, it would be very helpful for me.
Thank you
Message 11 of 13
(1,807 Views)
Hi Klemen,
               i have integrated it,check it whether it is correct,if it is correct,
I am giving  32 as maxcolor input,but the values for R is 26 instance and G is 26 instance and for B is 25 instance.
why i am getting the value as 32?
Regards
Madhubalan
Message 12 of 13
(1,802 Views)
read some literature regarding the Octree quantization to understand it better. The octree pallete does not guarantee the exact specified number of colors.
Start here: http://www.microsoft.com/msj/archive/S3F1.aspx
And also, you can simplify your code and count the number of colors here:
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 13 of 13
(1,798 Views)
