This widget could not be displayed.
Machine Vision
Looking for a the right camera....
I’m looking for an indoor USB webcamera that supports a manual lens.
I’ve yet to find such a webcam but machine vision cameras seem well built for such a task (and then some).
The machine vision cameras I'm most interested in (Point Grey Research's Firefly MV or Lumenera's Lw115) are USB based color (~30fps) cameras that should require very little human interaction to operate long-term (the way it needs to be). I.E. once the camera is mounted, the manual lens adjusted/locked down and the cables are setup between the cameras and the computer; the cameras should passively turn on and off as the computer does and allowing for a very efficient system.
The only issue is these cameras are expensive and designed to capture video that is far more accurately then is really necessary while being used as a webcam. Hence I refer back to my statement above, I need an indoor USB webcamera that supports a manual lens. A prefect product would be the equivalent to a high-end Logitech webcam with a CS-mount designed into it and hopefully costing around $150a piece for a VGA camera or $250 a piece for a 1.3 Megapixal camera (USD).
I don't think this prefect camera really exists but I would like some video experts to confirm or deny this fact and let me know where or not I’m making a good investment to use machine cameras as webcams.
Thanks for reading,
Reactor89
(4,658 Views)
Some of the USB web cameras use M12 lenses, see http://www.webcaddy.com.au/astro/M12Cameras.htm.  You can partially disassemble these cameras and replace the lens with an M12 lens of your choice:
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2589
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2660
With a bit more effort, you can modify pretty much any USB camera to work with a C-Mount lens,
http://ghonis2.ho8.com/Pro9000a.html
http://www.david-laserscanner.com/forum/viewtopic.php?p=7805
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(4,638 Views)
Ah... It warms my heart to see unsuspecting webcams disassemble and turned into cameras they where never meant to be. 😄
Anyway thanks a bunch Robert, very interesting links. I not sure whether or not I will be building custom cameras for the project I'm currently working on but it's nice to have the option regardless.
Also if I was going to modify a webcam to support a lens, what would be the best way to determine the image sensor characteristics/spec so I can choose a proper lens.
I figure that the company that sells me the webcam won't tell me I and should have some knowledge on how to get this information myself.
Suggestions welcome.
Thanks again,
Reactor89
(4,599 Views)
Accepted by topic author Reactor89
There are consumer reviews posted for particular cameras.  I would use a search engine and type in the particular manufacturer or model number followed by the word review.  To get more technical information about a particular manufacturer or model number, type in the name followed by something specific like camera sensor size.  You should be able to locate specs like
http://reviews.cnet.com/webcams/logitech-quickcam-pro-3000/4540-6502_7-3126139-4.html?tag=rnav
Of the web pages that I visited, CNET seems to have the most information.  The specifications of the camera's sensor will tell you something about its performance.  I would look for a low density CCD sensor.  A 1/3" format CCD with 640 x 480 pixels will usually outperfom a 1/4" format CCD with the same number of pixels.  CCD sensors will tend to outperform CMOS sensors.
Robert Eastlund
(4,574 Views)
