Machine Vision
Low level serial communication imaq c++
I have a PCIe-1427 and am making an application  which can set camera configuration parameters via serial communication through camera link. I am using visual c++ with window vista. Can  I get an example that uses imgSessionSerialRead, imgSessionSerialWrite, imgSessionSerialFlush, and imgSessionSerialReadBytes. For example I would like to get a camera information by sending a command of "opr?". I tried to find an example in the folder of c:\Program Files\National Instruments\NI-IMAQ\sample\MSVC but I couldn't. How can I define a buffer and buffer size to contain "opr?"? How can I define settings for serial communication like baud rate etc.
Thank you
Ahn
(3,297 Views)
Hello Ahn,
We do not have any examples shipped with LabVIEW that use the 'imgSession' functions. I would recommend taking a look at this forum post, as it addresses your questions very clearly. As mentioned in this post, settings for serial communication such as baud rate are defined by the camera file.
I hope this helps. Please post if you have any other questions.
Vivek Nath
Machine Vision
(3,286 Views)
