Machine Vision
MAX Hardware detection issue for a FireWire camera
Hi Everybody,
I'm translating an image acquisition system from an "old" PC (Dell Optiplex GX280 / Win 7) from on other on Win7 (PC2).
The image acquisition is connected to PCs with  PCI fireWire boards and automatically detected in MAX wiht the IMAQdx and reconnect them as : cam microsoft DV Camera and VCR.
However :
Wiht the "old" PC is can grab or snap the camera
Wiht the PC2 a error message is display : "Error Loading control. The default settings for the control will be used"
PS: Both PC run on Win7 wiht the same IEEE 1394 Driver (OHCI legacy) and LV2013.
Thank you so much for your help !
Best,
manu
(999 Views)
Make sure you have installed camera driver's in the PC2
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(969 Views)
