Machine Vision
MAX does not see PCI-8252
i have a problem with PCI-8252 acquisition board (used with a Basler Scout Camera scA750-60fm).
Max does not recognize the NI-IMAQ device for IEEE 1394 (both connecting the camera to the board, both keeping firewire cable unconnected) . I tried to install both software and hardware, but without success.
I can see the PCI-8252 board into the windows device manager. It's name is "Controller host texas instruments IEEE 1394 compatible OHCI".
My software is updated to the following versions:
NI-IMAQ for 1394 v.2.0.5
NI-IMAQ 4.2
NI-IMAQdx 3.2
can you help me?
(3,258 Views)
Hi Martim,
It's normal that PCI 8252 is not seen under MAX device list, since it mounts a 3rd party IEEE controller. Anyway you can see it under Windows device Manager.
For what concerns your issue, take a look into the following document:
Troubleshooting FireWire (IEEE 1394) Camera Installation Problems
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,241 Views)
