Machine Vision
Machine vision system
Hi Everybody,
I'm a student, and now i'm interning at a company that wants me to develop an industrial vision systeme.
I would like to ask you if i can use vision builder for automated inspection (VBAI) with the Labwindows/ CVI
If so, how? and what are the difficulties that may affect me?
THANK YOU for your help !
Message 1 of 12
(5,914 Views)
Hi Everybody,
Message 2 of 12
(5,899 Views)
You can use the VBAI API which includes and LabVIEW, C, and dotNET interface for controlling and interacting with a Vision Builder AI engine.  Here's a video that demonstrates how to use the API to load inspections, run them, get results, images, and you can even set variable values to affect how the inspection runs.
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
You can also find a shipping examples for CVI here:
C:\Users\Public\Documents\National Instruments\Vision Builder AI 2015\Examples\API Examples\CVI Examples
Hope that helps,
Brad
Message 3 of 12
(5,909 Views)
I appreciate your answer,
I wanted that I use the Labview with the VBAI, but my supervisor wants me to use the CVI, although all the tutoriels are vision builder + CVI.
I didn't found argument how to convince him that using labview is better.
Message 4 of 12
(5,896 Views)
You already posted this on the machine vision forum: http://forums.ni.com/t5/Machine-Vision/Machine-vision-system/m-p/3574832
No need to post the same topic on multiple discussion boards. Use the Vision forum for this request.
Message 5 of 12
(5,889 Views)
I would recommend you do what your supervisor wants. The programming language is a user preference, and either will work for communication with Vision Builder AI.
Message 6 of 12
(5,870 Views)
Thank you Sir,
but i didn't understand the difference between VBAI and VBAI API ?
is VBAI API another software? or is it just a configuration that we make on the VBAI to generate for us a C code?
Message 7 of 12
(5,838 Views)
What about using ActiveX in the CVI ?
Message 8 of 12
(5,826 Views)
Accepted by topic author Arrouma
ActiveX is no longer supported as a way to control Vision Builder.
Vision Builder (VBAI) is the configurable environment where you create your inspection.
VBAI API is the set of functions in LabVIEW, C, or dotNET that you can call to interact/control a Vision Builder Engine.
The Vision Builder Engine is the run time version of VBAI. It can run inspection and be controlled from the API function calls but users can't edit inspections with it or interact directly with it.
When you install VBAI, you have the option to include the API and this will also give you access to launching local VBAI engines or connecting to VBAI Engines running on targets.
Hope this helps clarify things.
Brad
Message 9 of 12
(5,820 Views)
Thank you a lot Mr Brad you have resolved my problem,
Just one more question , will i use VBAI API or C API to control or call my inspection ?
Message 10 of 12
(5,780 Views)
