Machine Vision
Marble slab
You might want to consider installing a light baffle below the line. This would act has a light absorber and give you a low level uniform background. There are some extremely absorbent light absorbing materials on the market - relatively inexpensive.
Message 41 of 46
(1,470 Views)
Hello Simon,at the moment we can't install that.
The background ist relatively good. I think some image processing makes the work there. Any ideas?
Message 42 of 46
(1,468 Views)
You could create a mask from the image and use this to extract just the region of interest you are looking at. I've not had chance to look at your script but I might start with something like this.
Message 43 of 46
(1,465 Views)
Hello Simon,
We have always different marbles. Size and color are changing:
Some marbles natural holes on them. We want to detect these holes. too So, i don't want use "fill holes"
Marble slab with holesMarble slab with holes
Message 44 of 46
(1,451 Views)
Since it is a line scan camera, the background image is fairly constant.  You could create a background image with no marble, then subtract that from the marble image.  This will cancel out the background and make it almost zero.  You can then do a manual threshold using a fairly small value.  This would keep the holes and other features of the marble.
Bruce
Bruce Ammons
Ammons Engineering
Message 45 of 46
(1,442 Views)
Hello Simon,
"Line profiling" in your script and suggestion of using mask gave me ideas to solve my problem. Thank you.
Message 46 of 46
(1,435 Views)
