Machine Vision
Memory leak in imaqFindPattern
I suspect a memory leak in imaqFindPattern()
When I run this function in a loop the amount of RAM used by the program increases step by step. When I disable two statements in the loop, the amount of RAM used remains the same. The two lines that I toggle are:
pm=imaqFindPattern(input_image,ref_image,some_rect,&options,NULL,&n);
if(pm) imaqDispose(pm);
I added an 'else' to the 'if', but it is never executed.
It happens also when I use the same image every time in the loop.
I used NI Vision 8.6 and CV 8.01 on Windows XP.
Please confirm or help. 😉
(5,838 Views)
Could you please post a copy of the input image, reference image, rectangle, and options you are using?  It will help isolate the problem much more quickly.
(5,828 Views)
These are the options:
 // Init FindPattern Options
 IPFindPatternOptions.angleRanges=NULL;
 IPFindPatternOptions.minMatchScore=100;
 IPFindPatternOptions.mode=IMAQ_MATCH_SHIFT_INVARIANT;
 IPFindPatternOptions.numMatchesRequested=1;
 IPFindPatternOptions.numRanges=0;
 IPFindPatternOptions.showResult=FALSE;
 IPFindPatternOptions.showSearchArea=TRUE;
 IPFindPatternOptions.subpixelAccuracy=FALSE;
It's a little bit hard for me to attach pictures, because it is about checking passport images, so personal data is involved.
When I run the (very stripped) program below, I do not have a memory leak.
In my original program, when I comment the imaqFindPattern(...) statement there is no leak, when I include it, there is a memory leak.
I have tried the alternative with imaqLearnPattern(...) and imaqMatchPattern(...) but that also leaks.
Maybe someone knows about a good memory leak finder (if such exists)?
This is the program that does not leak:
#include <windows.h>
#include "nivision.h"
#include "nimachinevision.h"
static FindPatternOptions o;
// main
int main(int argc,char *argv[])
 Image *SrcImg,*RefImg;
 PatternMatch *pm;
 int i,n;
 SrcImg=imaqCreateImage(IMAQ_IMAGE_U8,0);
 imaqReadFile(SrcImg,"SrcImg.png",NULL,NULL);
 RefImg=imaqCreateImage(IMAQ_IMAGE_U8,0);
 imaqReadFile(RefImg,"RefImg.jpg",NULL,NULL);
 // Init FindPattern options
 o.angleRanges=NULL;
 o.minMatchScore=100;
 o.mode=IMAQ_MATCH_SHIFT_INVARIANT;
 o.numMatchesRequested=1;
 o.numRanges=0;
 o.showResult=TRUE;
 o.showSearchArea=TRUE;
 o.subpixelAccuracy=FALSE;
 for(i=0;i<25;i++)
  printf("%d\n",i);
  pm=imaqFindPattern(SrcImg,RefImg,IMAQ_NO_ROTATED_RECT,&o,NULL,&n);
  Sleep(1000);
 return 0;
(5,768 Views)
Has there been any progress on this discussion?  I am also experiencing memory issues that my be related to the FindPattern function.  I believe I would find the results of this discussion very helpful.
Manson
Message Edited by A Wooten on 07-06-2009 09:17 AM
(5,480 Views)
It is still an issue for me!
I have attached two TaskManager images of my program. In the first image my program runs with two source code lines turned OFF:
    pm=imaqFindPattern(input_image,ref_image,RectROI,&PhotoFindPatternOptions,NULL,&n);
    if(pm!=NULL) {imaqDispose(pm); pm=NULL;}
And in the second image my program runs with these two source code lines turned ON.
I know this does not make much sense running the program with these lines turned ON, but it is a way to be sure that the memory leak is in these two lines.
The result is obious: there is a memory leak in this function!
MatchPattern turned OFF
MatchPattern turned ON
Message Edited by iai on 11-03-2009 02:55 AM
Message Edited by iai on 11-03-2009 02:56 AM
(5,254 Views)
Accepted by topic author RobKijger
Good news! After installing the NI-Vision update 8.6.1 the memory leak disappeared!
So, if you have memory issues with imaqFindPattern, locate, install and download the 27Mb NI update.
(5,224 Views)
That is good news!  Unfortunately I am using an older version of the Vision Development module (v7.1.0).  Is there an update available  for my version?
(5,217 Views)
