Machine Vision
Migrate VBAI3.5 to LV using CVS1454
Hi All,
I have created a simple Vision Builder inspection (VBAI 3.5) where I take an image from my camera (Foculus 1394 connected to my CVS1454) and save it.  I have "Migrated" the VBAI code to LabView8.5, but whan I try to run it in LabView, it stops with an error of ERR -1074364402 in the setup 1394RT.  I have tried it in a project with the CVS1454 as a target, but it does the same thing.  Does anyone have suggestions on simple steps I can take to make this work?  Thank You.
(2,890 Views)
Hi SBonham,
One thing to look at is if you still have VBAI on the CVS.  When you are trying to target the CVS from LabVIEW you have to first remove VBAI from the CVS.  Did you do this before hand?  Also you should make sure that you are using IMAQ for 1394.  The CVS does not support IMAQ dx.  If those two things do not work let me know and it might be helpful if I could see a screen shot of the error its self.
Adam H
(2,874 Views)
