Machine Vision
Multiple Camera Acquisition with one PCI-1410 framegrabber
    I use A6804 to connect two cameras (60Hz Progressive scan) in V1 and V2. I have no idea how to continuously get images from both cameras.
 I've looked up any possible solutions of my problem in this forum, but I still cannot get it...
 According to what I've known, PCI-1410 has only one ADC so when one channel (e.g., channel 1) gets full frame image,
I have to switch to the other channel (e.g., channel 2) to get other full frame image, then back to channel 1. Is this possible?
I would like to know how to send trig signals so that I can alter between each channel and get full frame image.
A topic in this forum suggested use 'imgPulseRate', 'imgPulseCreate', and 'imgPulseStart' before 'imgSessionConfigure', but I dont know how to and I dont have example for this.
Could somebody tell me how to do or have example CVI code for this? Thanks for your help. 🙂
(3,701 Views)
您是否在幾天前問過NI工程師,建議您先與NI業務工程師約時間,然後把設備帶去NI,請工程師現場解說(如果學校距離NI很近的話)
(3,690 Views)
嗯, 請問敦化南路和基隆路那個台北辦公室就可以了嗎?
謝謝你的回應。 🙂
(3,684 Views)
請您 call 02-2377-2222x7144
(3,674 Views)
