Machine Vision
Multiple images onto frontpanel
I try to simultainously display multiple images inside/onto a front panel. How is this posible without getting the images "floating" around onto the panel? (They shall stay on top, but be attached to the panel.)
I have tried using a sub-vi called Make Child.vi which someone have made, but this only works for one image, the rest of them "floates"
Help?
(4,003 Views)
Sondre,
The Make Child vi has a bug in it that only allows you to make window 0 into a child panel. I cleaned up the vi and fixed it so that you can make any IMAQ display a child window. My version is attached.
Bruce
Bruce Ammons
Ammons Engineering
(4,003 Views)
I'm curious what you did to fix this bug. I noticed an older version has "IMAQ WindMove.vi" in it set to GET the coordinates (basically does nothing), while your version omits this VI. Is this the change you made?
(4,003 Views)
Hi Bruce..
I do need this particular example, but when I run it I cant find the 'IMAQ Get Window Handle.vi'.Could you please help out?am using ver. 6.0
Thanxs,Veena
(4,003 Views)
I couldn't see anything that required the IMAQ WindMove, so I took it out. That was not the bug, though. There was another spot where I wired in the correct window number, instead of letting it default to zero.
Bruce
Bruce Ammons
Ammons Engineering
(4,003 Views)
It should be part of the IMAQ toolkit. I have noticed that it sometimes disappears, though. You might want to try reinstalling the toolkit. I am guessing you updated something else, like the IMAQ drivers, since you installed Vision.
Also make sure you install the patch to get up to 6.0.5.
Bruce
Bruce Ammons
Ammons Engineering
(4,003 Views)
