Machine Vision
My output image getting blurred .. while doing pattern matching (image process)
Hi all,
Spoiler
            I did pattern matching program using Vision Express . here if i aquire image my output is smooth . if i do some image process like ( pattern matching or  Edge detection ) my output image getting blur ..
I have added My VI and that fault iamge as example
(6,273 Views)
Hi saran,
-can you provide your acquired image and the image after processing?
-Are you sure of providing proper buffers for images?
-Any reason why there are two consumer loops and only one of them is doing some processing?
-If you are using pattern matching and edge detection, the image will not change.
uday
(6,250 Views)
    Its Not about Image that i have captured ...if i do some pattern matching or circle find only my image getting blure..
(6,247 Views)
Hi Uday .
             I have another Question ..While i am doing Circle finding I need to specify ROI mauanlly .. how to assign maually .
(6,245 Views)
Like i am finding pattern matching from that result of coordinates i have to use that value to ROI of circle finder ... how to do this? any idea
(6,245 Views)
Can you try with pattern matching example (post vis) and see if your image is getting blurred? instead of vision assistant?
-Again, pattern matching will not alter your image unless there is something wrong with buffers....
Edit: for ROI selection check this http://zone.ni.com/reference/en-XX/help/370281P-01/nivisionlvbasics/define_regions_of_interest/#Defi...
uday
(6,242 Views)
whether i have to use seperate buffer ? for pattern matching ?
(6,240 Views)
