Machine Vision
My task is to investigate a possibility of a very detailed inspection of an automotive push button using NI hardware/software. We are looking for debris, uneven intensity, scratches etc. How can I do that? What tools/methodology to use?
Jerry,
The hardest part is probably defining precisely what you are testing.
You need to get good lighting to evenly illuminate the entire surface with no glare or dark areas. You probably need a good color camera.
Once you have a good picture, you will use different processing to detect different features. For example, scratches and debris could be located by using edge detection and checking for edges in areas that shouldn't have any edges (center of button, etc.). Perhaps examining the color with certain limits would locate discolored areas (too dark, too light, wrong color, etc.)
Bruce
Bruce Ammons
Ammons Engineering
(3,591 Views)
