Machine Vision
NI 1450 ethernet protocol
Looking for any comm spec's for the ethernet protocol, Need to see if I can communicate with
an AB Compactlogix via ethernet. If not I'll probably have to go over 232
Jason
(3,095 Views)
Hi Jason,
You can use the TCP functions in Vision Builder (if you're using that with the CVS) or the TCP VIs in LabVIEW Real-Time to communicate over the ethernet port, or of course you can use the built-in RS-232 port to communicate that way if you'd like.
(3,077 Views)
