Machine Vision
NI 1772 Accessory I/O addressing
I've got an NI 1772 smart camera that came with a Power/Accessory block with physical I/O on it. How do I address these physical I/O in the Labview code? Eg. using a case structure, if 'input 1' is high, then execute the 'True' case etc. How do I address 'input 1' in the code?
I know this is probably really simple, but I still can't figure this out after hours of Google'ing. Any pointers is appreciated! 🙂
(3,543 Views)
There are two included examples that should show you what you need to do:
(3,533 Views)
Oh man, I should have looked in the examples before posting... thanks for your help!
(3,503 Views)
