Machine Vision
NI-CAN Series 1 problem with windows 7
Hi.
I have a NI-CAN Series 1 card used with windows 7 64 bit OS. My CAN card communicates with an external device which i´m able to receive data from, but sending data doesn´t work anymore (i have tested this with drivers 2.6.3 and 2.7.2).
Previously, i have used the card in a windows XP environment and everything worked fine, i also tried the same driver (2.7.2) and it still worked.
I have searched the forums but can´t find any related articles on the subject.
It seems to me that there is a problem with the driver not supporting my CAN card in a windows 7 environment, because i also get the same problem with windows 7 32 bit OS.
Note: the readme files mentioned 2 unsupported CAN serial 1 cards, but my card is not one of them. So, i guess it should still work..
If anyone can help me it will be highly appreciated..
best regards
Hans-Petter Andersen
(3,210 Views)
Were you able to get your series 1 can card to work with windows 7?
(3,049 Views)
I'm looking for NI-CAN Series 1 card for my tester. Can anyone tell me where I can find this card.
Raja
(3,011 Views)
Hi Raja,
Please contact your local NI Office in this matter as they will be able to answer your question.
Best regards
Richard Wasell
(3,007 Views)
