Machine Vision
NI GigE Vision Adapter Driver not compatible
Hello everyone,
I’m trying to install the NI GigE Vision Adapter driver for a network adapter, but It seems  the hardware is not compatible.
If I install the driver ( deselect compatibility box), Windows sometimes crashes and the cameras are no longer recognized by MAX. And there is no package sent via network.
I have installed VAS 2014, VAS 2015 f1 and VAS 2016. But each time I had  the  error "The NI GigE Vision 64-bit Driver Support installation has failed"( see attached picture)  while installing.
Network cables were unplugged, PCI network card wasn't.
However, I have an identical system, software and hardware ( with VAS 2016), that works fine. I can see the NI GigE Vision Adapter driver as a compatible driver for my hardware.
The network card is a Beckhoff PCI FC 9024. System is Windows 7 Ultimate, 64-bit, LabView 2012 32-bit.
PS: The cameras are working with the actual driver, but with maximum package at 1500 bytes. To less for what I need.
It's mandatory to use the performance driver.
 Any suggestions?
Thank you!
Message 1 of 1
(2,633 Views)
