Machine Vision
NI-IMAQ: The passed in interface or session is invalid
I'm trying to use a USB camera (thorlabs DCC1240c) with the "Grab and save to AVI.vi" example.
When I run the file i got "NI-IMAQ:  The passed in interface or session is invalid".
I checked in NI MAX and the interface name of the camera is cam0 and that's what I entered in the "Interface name" box in the front panel.
What's the problem ?
Thanks in advance,
Gabriel
Message 1 of 10
(10,317 Views)
Hi Gabriel_B,
-Please tell me in MAX Under which category you can see your device: NI IMAQ or NI IMAQdx?
-If it's under IMAQdx, Grab and Save to AVI.vi will give the error.
uday
Message 2 of 10
(10,315 Views)
it is in NI-IMAQdx Devices.
How can I change it then ?
Thanks for your help
Message 3 of 10
(10,307 Views)
Accepted by topic author Gabriel_B
-Replace all IMAQ vis with IMAQdx vis.
uday
Message 4 of 10
(10,297 Views)
Thanks a lot, it works fine now 😉
Have a nice day.
Gabriel
Message 5 of 10
(10,282 Views)
Kudoes always welcomed 😛
uday
Message 6 of 10
(10,279 Views)
But I can find out the IMAQdx AVI vis, there are IMAQ AVI2 vis in labview2015 only, thanks
Message 7 of 10
(7,769 Views)
I used LabWindows/CVI and got the same error message when use a USB camera (Logi C270 HD WebCam).
I can see the camera under Devices and Interfaces as "cam0".
Function call imgInterfaceOpen ("cam0", &Iid);  will return 0xbff60015 error message.
The passed in interface or session is invalid.
Message 8 of 10
(1,224 Views)
I can't find NI-IMAQ, NI-IMAQdx setting in MAX.
Message 9 of 10
(1,218 Views)
I found solution here.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kEwBSAU&l=zh-TW
https://www.ni.com/en/support/documentation/compatibility/25/ni-vision-driver-and-vision-acquisition...
NI-IMAQdx
The NI-IMAQdx driver software is needed to use third-party image acquisition devices which use the following buses and standards:
  • Gigabit Ethernet Cameras Supporting GigE Vision
  • FireWire IEEE 1394 Cameras
  • USB 2.0 Cameras Supporting Microsoft DirectShow
  • USB 3.0 Cameras Supporting USB3 Vision
Message 10 of 10
(1,212 Views)
