12-20-2017 09:13 AM
please tell how to rectify the error.. i am using a webcam which is installed in my laptop.. when i assign the number of buffers to 5 and set the camera session to cam1 or cam0 the error is coming like this which i posted in the screenshot..
please let me know what to do to overcome this error..
12-20-2017 09:22 AM
You're getting an error here because you're using two different APIs. A webcam should use the IMAQdx API, which you're doing correctly for the session open, configure, start, and stop. You can tell by the small "dx" in the bottom left corner of the icons. The Configure List, Configure Buffer, Get Buffer, and Extract Buffer VIs are from the IMAQ API, so they are not expected to work with an IMAQdx camera/session. Take a look at the IMAQdx example VIs to see which IMAQdx functions you should be using to get images (C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\Vision Acquisition\NI-IMAQdx\High Level\Grab.vi).
Hope this helps,
Katie
12-20-2017 09:50 AM
i am new to labview can you please rectify the program in order to avoid the error.. i am still getting the same error..
otherwise can you tell in detail how to do it
12-22-2017 01:56 PM
Take a look at the IMAQdx acquisition examples in the Example Finder (Help>>Find Examples...>>Hardware Input and Output>>Vision Acquisition>>NI-IMAQdx). You'll see lots of examples for doing different kinds of acquisitions.
-Jordan
