08-29-2005 10:05 AM
08-30-2005 01:25 PM
Hi
Question 1: Yes. I am using logitech quickcam pro 4000 and it runs fine. I tried different logitech webcams an all of then run fine. Obviously, there are some differences in picture quality....
Questios 2: I am not sure about that, but probably most webcams that run under Windows will support Directshow.
You can email manufacturer to make sure it will run.
09-03-2005 08:17 AM
Thank you.
i will buy the logitech QuickCam 4000.
09-04-2005 01:23 PM
Hi Alipio,
i just install this camera and use the IMAQ - USB Driver with my LabView Vision Module 7.1.1
its work perfect !!!
Thank you very much.
i'm trying it now and i think i can use it for test for my real application to test some algoritms and methods.
i having some problems with Color Patern Matching i want to use , but i try do work around and find the problem.
thanks in advanced for any help.
mor.
09-27-2005 05:24 PM
Does this driver work with vision 6.0?? If it doesn't can anybody suggest a way to use USB camera with vision 6.0?? thank you
09-28-2005 01:08 AM
10-04-2005 07:42 PM
Thank you very much
rsa
10-12-2005 02:36 PM
I have bought the Logitech Quickcam 4000 but have a problem with Labview 7.1 and Vision Assistent 7.1.1
I've seen the problem earlier in the forum. but did't find a solution.
The problem is the System Memory failure in Labview and the wrong camera settings in Assistent.
Can anybody help??![]()
10-13-2005 11:34 AM
10-13-2005 05:26 PM
National Instruments' application engineers do not support the NI-IMAQ for USB Cameras driver. As an applications engineer, I have very little experience with this driver, but I will be happy to help. Can you please provide more information (error codes (ex. -70837596), where the error is occurring, etc)?
Ryan M.
Applications Engineer
