Machine Vision
NI-IMAQ for USB and usb Cameras
Hi all,
I need help in choosing USB camera.
1)
 is NI-IMAQ for USB Cameras Support  this web camera :
 Logitech QuickCam® Pro 4000  ?
2)
I know that USB Camera that works with NI-IMAQ for USB
must support  "DirectShow" , How i can be sure that the WebCam
that i want to buy support Directshow, its not mentioned on the box, nor in the product description in the website.
any links for Web camera (usb) that works with the NI-IMAQ for USB
will be very helpfull.
Mor
Message 1 of 56
(9,524 Views)
Hi
Question 1:  Yes. I am using logitech quickcam pro 4000 and it runs fine. I tried different logitech webcams an all of then run fine. Obviously, there are some differences in picture quality....
Questios 2: I am not sure about that, but probably most webcams that run under Windows will support Directshow.
You can email manufacturer to make sure it will run.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 2 of 56
(9,468 Views)
Thank you.
i will buy the logitech QuickCam 4000.
Message 3 of 56
(9,438 Views)
Hi  Alipio,
i just install this camera and use the IMAQ - USB Driver  with my LabView Vision Module 7.1.1
its work perfect !!!
Thank you very much.
i'm trying it now and i think i can use it for test for my real application to test some algoritms and methods.
i having some problems with Color Patern  Matching i want to use , but i try do work around and find the problem.
thanks in advanced for any help.
mor.
Message 4 of 56
(9,432 Views)
Does this driver work with vision 6.0?? If it doesn't can anybody suggest a way to use USB camera with vision 6.0?? thank you
Message 5 of 56
(9,298 Views)
Hello
I guess the NI USB webcam driver works only with IMAQ vision 7.1.
There are activex and toolkits to use webcams in Labview. search this forums.
I recommend you to download ROBOLAB for Labview    http://www.ceeo.tufts.edu/robolabatceeo/college/robolabforlabview/default.asp . Its multimedia tools will allow you to grab pictures using a USB webcam and convert to IMAQ format for further processing. I only tested it to grab pictures and seems to be quite good and integrates fine with Labview. Not sure if it will run using vision 6.0 but you can try.
hope it helps
Alipio
Message 6 of 56
(9,292 Views)
Thank you very much
rsa
Message 7 of 56
(9,207 Views)
I have bought the Logitech Quickcam 4000 but have a problem with Labview 7.1 and Vision Assistent 7.1.1
I've seen the problem earlier in the forum. but did't find a solution.
The problem is the System Memory failure in Labview and the wrong camera settings in Assistent.
Can anybody help??Smiley Sad
Message 8 of 56
(9,064 Views)
I have the same problem, i have bought a logitech quick cam express and i cant comunicate it with labview or vision asistant 7.1
Please could you help me
I dont know how to continue my student project
Fernando Mora Torrijo
Spanish studient
Message 9 of 56
(9,025 Views)
National Instruments' application engineers do not support the NI-IMAQ for USB Cameras driver.  As an applications engineer, I have very little experience with this driver, but I will be happy to help.  Can you please provide more information (error codes (ex. -70837596), where the error is occurring, etc)?
Ryan M.
Message 10 of 56
(9,003 Views)
