Machine Vision
NI-IMAQdx compatibility with GeoVision GV-FE110
Can anyone tell me if this IP camera is compatible with NI-IMAQdx..
GeoVision GV-FE110
That is, will it be seen by MAX and integrate with my other AXIS IP cameras.
The manual is here:  http://www.apexcctv.com/support/Downloads/IPCameras/GeoVision/GV-FE110/GV-FE110_manual.pdf
The specs are on page 103.
Thanks for any advice.
Phil.
Get a life? This IS my life!
(3,499 Views)
OK, since there are no immediate replies, can anyone tell me of an updated list of IMAQdx "compatible" IP-cameras.
or even better, is there a way for me to figure it out for myself?  It seems like there must be some basic capabilities that LV requires...  or is it a metter of a driver being written for each camera/brand?
There is custom viewer software with the camera that is proprietary, but apparently the video is also viewable through a browser, but only with an AxtiveX control loaded.
Phil.
ps: I'd just buy one and try it, but they are $400 each.
ps: I'm looking for a NI compatible wide angle (this one is a 360 fish eye) IP camera for an underwater robot.
Phil
(3,490 Views)
Hi Philbot,
As of now, IMAQdx supports only Axis and Basler IP cameras. It is a matter of a driver being written for the camera, but there is a chance you can get it to work.
shows a way to connect and I have seen in the manual that the camera does support the mjpeg codec.
As to IP cameras that would be compatible and wide angle, you can check https://www.ni.com/en-us/shop/category/machine-vision.html or Axis or Basler's site to find a camera that meets your specs and put a wide angle fish eye lens on it. Does it need to be waterproof?
DylanC
(3,484 Views)
