Machine Vision
NI-IMAQdx driver?
I'm attempting to rebuild a system that uses an old IEEE 1394 camera.
I have vision 2019 installed (I believe this is the last version that supports firewire cams) but I'm unable to get the camera added in MAX.
In VBAI, if I click the capture image button, a dialog appears telling me I need NI-IMAQdx drivers.  I found an knowledge base article addressing the same issue which states this is automatically installed with VBAI, but this doesn't seem to be the case, only IMAQmx is installed.
Does anyone have any advice on how to either get the driver (I searched the site, which isn't easy, but didn't find anything) or get these cams working?
I know all of the hardware and software are compatible as this worked before we lost the OS.
Thank you for any advice.
EDIT:  I think I figured out how to install the driver, hopefully the rest will be 'figureoutable' from here.
Message 1 of 1
(1,126 Views)
