Machine Vision
NI-MAX noncontinuable exception
Hi all
See the attached screen shot. When I try to change the camera file in NI-MAX, I get this "noncontinuable exception". The file in question worked last week, and in fact NI-MAX won't let me change to any camera file that should work with this camera.  The camera is an evaluation board from a sensor vendor, and the .icd file that I'm trying to switch to came from them - it's actually working with my modified .icd file. To me, this is the strangest part: the hardware is working, everything is talking to each other, I just can't change camera files.
I tried running NI-MAX as an administrator, thinking corporate IT might have pushed out a permissions change. When I run as admin, and select the new camera file, NI-MAX just crashes, no pop-up, and the file still doesn't change.
Windows 7; NI-MAX 14.5, LV 2014
PCIe-1433 framegrabber
I'm going to try saving a file in Camera File Generator. I'll post more info if I learn anything.
Thanks!
MADman
(4,669 Views)
Quick update: I edited the ICD file that's working (removed the attribute I had added), saved it to a new filename, and tried switching to the new file. Same error message.
BUT
I made a copy of my file, using Windows Explorer copy/paste, then used NI-MAX to switch to the copy. That worked, and switching back worked, too.
(4,665 Views)
I also tried repairing the NI-IMAQ installation. Not sure it really changed anything.
I have this thumb drive with LV2015 on it. I'll install that and see what happens.
(4,657 Views)
Accepted by topic author sdmadman
Installing LV2015 did indeed fix the NI-MAX problem. So some part of my previous installation got corrupted. When I tried to repair the installation earlier today, I didn't have the VAS installation media handy (or I may have deleted the download like an idiot), so I skipped that repair. Seems likely now that the problem lay in VAS somewhere.
Cheers!
MADman
(4,649 Views)
