Machine Vision
NI PCIe-1427
Hi. We've got Ni PCie 1427 framegrabber and mdr 26 to sdr 26 cable.
I'm trying to transmit frames from FPGA board to framegrabber.
Ive implemented only x0+/-, x1+/-, x2+/-, x3+/- and xclk+/- signals.
Frame parametrs are 120 fps, 12 bit pixel, 120 x 80 size.
I've connected board and framegrabber and then I'm trying to grab frame by NI software I got with framegrabber.
The questions are:
 Is it enough x0+/-, x1+/-, x2+/-, x3+/- and xclk+/- signals for framegrabber  working? Can I grab frames only using these signals?
Should I use others signals of camera link base (CC1, CC2, CC3 ..., SerTFG, SerTC)?
(4,752 Views)
Hi farbius,
It’s dependent on what you’re doing with the camera but I believe you’ll need all signals. Below I’ve attached a resource with more information. On page 25 (3-2) there is more information regarding the signals and pinout.
http://www.visionx.cz/site/assets/files/1191/pcie-1427_manual.pdf
I’ve also linked a document with more information on the Camera Link standard. I believe the image under Bit assignments may be helpful for you.
https://en.wikipedia.org/wiki/Camera_Link
I hope this helps!
- Kale
(4,685 Views)
