Machine Vision
NI-PCIe1433 + Basler avA2040-180kc color image Problem
Hi all:
My sysyem:
WIN7 64bit
Labview2012 32bit
VISION2012 32bit
Frame Grabber: NI-PCIe 1433
Camera:Basler avA2040-180kc,(Pixel Data Format:Mono/Bayer GB...) (Camera Link interface)
My Question:
Run NI-MAX,this camera can grab color image,no problem.
But,when i run the Labview example code "HL Grab.VI",that image not color image, it look like Gray Image.
Why?
Has any Labview code can reference?
(4,790 Views)
have you tried modifying the example to change the image type? :
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,774 Views)
Hi Morbal ,
I guess it bayer encoding issue, you can refer to following link :
http://digital.ni.com/public.nsf/allkb/8AAAE9435D30CEB886256F80007A39AD
you can also find the example Snap with Bayer Decoding.vi form LabVIEW example finder.
Thanks.
Sean
Sean
(4,766 Views)
YA!!  This Problem has been resolved.
Add Bayer Decoding can solve this problem.
(4,761 Views)
